Knowing About ‘webpage Not Available’ Error
Hey, while browsing the internet, I am repeatedly getting ‘webpage not available’ error, while opening the web page. How do I fix this error? Here’s the snipped image of the error.
Hey there, can you mention which webpage you are trying to access? Is that webpage is still active or have been moved to a new address? With the limited information, you supplied, you can try deleting cookies. Cookies are the temporary files created in order to track the information of the visitor in specific web pages to ensure better service.
1. Click on ‘Settings’.
2. Click on ‘Advanced’.
3. Select ‘Content Settings’
4. Look for ‘Cookies’
5. Under ‘All Cookies and site data’, select ‘Remove All’
6. Restart the browser.
Hope this helps!
That message you see when you visit a website can mean that the website is down temporarily maybe due to a server problem. Try refreshing the page by pressing F5 on your keyboard or CTRL + F5 to force refresh. If this didn’t work, try visiting other websites to see if you can open them on your browser.
In case none of the websites you visited opened, check if your internet connection is working. If your computer is connected to a router, try resetting the router. Turn off your router and unplug it from the power for about 10 to 20 seconds. Press any button on the router to drain any leftover power.
After this, plug the router back to the power and turn it on. When the router is ready, try visiting a website and see if it works. On the other hand, if you can access other websites but not a particular website, the site is probably down temporarily. In this case, try visiting the site again after a couple of hours.
