Knowing the basic features and specifications of Sony PMW-F55
I want to know more about Sony PMW-F55. What are the benefits of using it? What are the specifications of this video camera? What is the use F55 sensor and beneficial is it in the camera? What is the difference of AXS-R5 outboard recorder from other recorder? What is Cooke/i and Arri LDS? What are the uses of this? What are the peripheral included with this camera? Does it include a tripod and extra batteries?
Answered By 0 points N/A #174079
            The PMW F55 Sony product features I can clearly explain to you. The power requirement is 12v DC, power consumption is approximately 25w, the operating temperature is 0 to 40degree Celsius.
            The dimensions of width, height and depth is 130*125*191 millimeters. The powered battery operating system is approximately 150mins maximum approximately 210 minutes.
            This device recording format is XAVC. The supplied accessories is Lens mount adaptor, Battery adaptor, Audio input connector, Tape measure hook, USB wireless LAN module and operating instructions (CD-ROM).
            The lens mount is PL mount and FZ mounts.
