Knowing a driver sound online detect
Is there a way online that can detect sound card driver in order for me to know what sound card driver to download? I re-installed Windows and sound card driver was not detected. Any help? Please tell me a way driver sound online detect. Thanks
Best Answer by Lawren chavez
Answered By 0 points N/A #144142
Hi Edward Rand,
You need to check out what your soundcard manufacture is. Then open your browser and search for that company. I think all manufactures have list of driver. You just choose the one suitable for your device and your operating system too. In order to find manufacture of your soundcard, open window explorer > right-click on computer > properties > device manager > choose sound and you will see the name of manufacture
If your do not want to find driver manually, open window explorer > right-click on computer > properties > device manager > choose sound > right-click on your device > properties > driver > update driver. Windows will find suitable driver for you
Hope this helps
Answered By 10 points N/A #144144
There are lots of ways to detect your sound card driver but you don't want to do it by yourself and you want to take the online help. I mean online your computer gets scanned for the drivers and give you the best drivers for your sound card. So I will suggest you two URLs to try your search with them.
The first URL will scan your computer and gives you the link also to download the driver.
http://www.radarsync.com/
The second URL has a software to download and install on your PC. Its the best one which gives you the detail and also the license key number of your products which is being installed on your computer and you have lost the license keys.
Answered By 0 points N/A #194916
Hi Dear,
In this era, internet has spread all around of the world.
We can get help in any case from the internet in seconds.
Now i come to your answer, you can detect and install sound or any driver online.
If you do not know your hardware model or sound card version then please visit this website.
https://www.driveridentifier.com/
This website provides a software called driver identifier. Just download and install it. It will scan all your computer for hard wares to update and install drivers. Then it will redirect you to driver download page.
Just download and install driver and enjoy.
System is must to reboot after installation of driver.
Thanks
