Knowing Minimum VSphere Server Requirements
Hey, I am unable to complete the VMware vCenter installation, probably because of system requirements. Can anyone let me know the minimum installation vSphere server requirements?
Hey there, In brief, I am writing minimum requirements, rest you can always refer documentation for the detailed prescription.
Operating System: 64-bit supported
Database: Microsoft SQL Server 2008 R2 Express, up to small deployments up to 5 hosts and/or 50 VMs
Processor: Intel or AMD x86(64-bit in case of vCenter Server 4.1), with two cores minimum and each of 2GHz frequency
RAM: 3 GB
Make sure DB requirements along with patch levels are compliant.
Hope it helps!
