alwyn white
20 points
Posted on - 04/07/2012
Hello everyone
I would like to install XAMPP on my laptop.
I have downloaded latest version of XAMPP and tried installing.
An error occurred showing its not compatible.
So before downloading I would like to know whether my laptop is a 32 bit or 64 bit.
Please help me to find.
Thanks
Knowing whether 32 bit or 64 bit
A processor is a main part of a computer that stays with Motherboard device. We may say it as a Central processing Unit or CPU for short word. A processor can increase or decrease computer’s performance.
If you use 32 bit processor then your pc will work more slow than 64 bit processor.
You can trace which bit operating system you are using by follow bellows method:
At first Click on Start Button then select All Program now choose Accessories in you program list in Laptop. Now select system tools and then select systeminformation. Â
Let you check the current window screen and if its show  x86 then you will be confirm that your using 32 bit and it shows AMD64 then you will be confirm that your using 64 bit operating system in your laptop.
Thanks
