Knowledge About Cisco ASA 5510 Memory Upgrade Features And Specifications
I am running a small business and I have heard about Cisco ASA 5500 series for providing securities due to the firewall. Can someone who is using Cisco ASA 5510 memory upgrade enlighten me about its various features and specifications?
Answered By 0 points N/A #298239
Cisco ASA 5510 series are comprehensive and highly effective in preventing the intrusions which help organizations to give secure, superior network and ensures basic resources for most extreme profitability. The main firewall conveys predominant adaptability, dependability on security intended to address the issues of a wide exhibit of organizations, and an expansive traverse of innovation arrangements including Cisco VPN to help distinctive sizes of endeavors to ensure and safeguard profitable corporate information. Various features and specifications are given below:
Feature Cisco ASA 5510
Users/Nodes Unlimited
Firewall Throughput Up to 300 Mbps
IPsec VPN Peers 250
Premium AnyConnect VPN Peers (Included/Maximum) 2/250
Concurrent Connections 50,000; 130,000
New Connections/Second 9000
Integrated Network Ports 5 Fast Ethernet ports, 2 Gigabit Ethernet+ 3 Fast Ethernet Ports
Virtual Interfaces (VLANs) 50/100
Security Contexts (Included/Maximum) 0/0 (Base); 2/5 (Security Plus)
Expansion Slot One, SSM
User-Accessible Flash Slot One
USB 2.0 Ports Two
Serial Ports 2 RJ-45, console and auxiliary
Mountable Rack Yes
Mountable Wall Not available
Physical Security Lock slot Not available
Memory Allotted 1 GB
Minimum System Flash 256 MB
System Bus Multi-bus architecture
Range of Line Voltage 100 to 240 VAC
Current in Amperes 3A
Frequency in Hertz 47/63 Hz, single phase
Steady state 150W
Maximum peak 190W
Maximum heat dissipation 648 BTU/hr.
Dimensions (H x W x D) 1.75 x 17.5 x 14.25 in. (4.45 x 20.04 x 36.20 cm)
Weight (with Power Supply) 9.07 kg
