joan_amante
10 points
Posted on - 09/24/2012
I tried installing Kodak ESP 725o network printer on Windows 8 Consumer Preview. The setup software detected the printer but this error appeared. I tried uninstalling it and restarted my computer and installed it back, it still happens. What do I do now?
Kodak Printer Installer
Printers
Operation could not be completed (errorÂ
0x8001010e).
The application called an interface thatÂ
was marshaled for a different thread.
Kodak Printer Installer; error 0x8001010e; operation could not be completed
There may be a compatibility issue with the Kodak printer installer and your operating system. Windows 8 consumer preview does not support some of the software that is supported by Windows 7. Try to search in its official website for Windows 8 compatible software.
Click on this link to go to the official website.
Thank you.
It seems like you are facing this problem due to compatibility issue. So try running in Window 7 Compatibility mode. Required steps are:
Find utility setup in start menu.
Right click and select ‘open file location’
Right click the exe file to choose properties.
Now click on Compatibility tab and set window 7.
Finally try to run the setup again and hopefully it will install.
