nathan
10 points
Posted on - 03/15/2012
There is a troublemaker in my PC: Kx0t7W4Fgi.exe
Everytime I turn on my PC this program executed automatically and followed by small pop up that contain message "missing blablabla .dll"
How to delete this annoying program??
Kx0t7W4Fgi.exe Automatically Executed When Start up
Hello Nathan.
It suspiciously looks like malware. To prevent it from starting up, download and install CCleaner. Go to Tools -> Startup and look for the executable. Click on Disable to prevent it from running at startup.
To ensure that the malware is removed and will not be re-enabled, try running these 2 freeware antivirus and anti-malware.
Download and install the free version of avast! Antivirus (https://www.avast.com/index). Be sure to enable the real-time shields.
Download and install the free version of Malwarebytes' Anti-Malware (or MBAM for short) (https://www.malwarebytes.com/premium/).
Scan your system with MBAM. With the real-time shield of avast! enabled, your system will also be scanned for viruses at the same time.
