Lab view error getting volume info
Error 7 appears in LabVIEW and I don’t know what is causing this. Is not the first error that I have in LabVIEW but is the first without a solution. Does anyone have a solution for my error please ? Can anyone tell me what is causing this error ?
Thanks !
Error 7 occurred at Get volume info in Error 7_with_Capitalized_Path.vi
Possible reasons:
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use as path separators on Windows,: on Mac OS , and / or Linux. Verify that the path is correct using the command prompt or file explorer.
