LabVIEW 2011 unknown exception error
30 points
Posted on - 10/28/2012
Hi all
I have just used LabVIEW 2011 to build a NI installer using the installer framework but when I try to execute the installer I built using LabVIEW, I get an error during the initialization phase. The screenshot of the error is attached below:
The message states:
LabVIEW 2011
Unknown exception
If anyone can please shed some light on the issue, I'll be really grateful.
Waiting for your comments and feedback.
Thanks and best regards.
