JUWAN24
Posted on - 10/26/2011
Hi TechyV community,
I'm using LabView Real-Time Module Version 2009 SP-1.
Hope somebody can get me past this error that I get every time I run the get target information.
I'm at the end of my rope.
Any idea to help me with this would be great.
Error 1 occurred at NI_Real-Time Libraries.lvlib:
RT Get Target Information (MAC).vi:1
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the
input is a path, the path might contain a character not
allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be
Controller-In-Charge.
Continue Stop
LabVIEW: An Input Parameter is Invalid
The error says the RT Get Target Information (MAC).VI:1.
Therefore, according to that MAC address must be input in hexadecimal format without the semicolons.
In order to input the MAC address in hexadecimal format under the conditions mentioned above;
First, right click on the string input to the MAC address input.
A menu will appear.
From that, Hex Display should be selected (fourth option counting from the very bottom of the menu).
The MAC address can then be inserted without the semicolons.
Hence, the RT controller's information can then be accessed by its MAC address.
And Hopefully, the problem is solved!
