LabVIEW load error code 3 occurred
My comp suddenly shut down and after restarting I couldn’t open any VI file.
I get the message shown below. Any ideas?
 LabView Generic error
An error occurred loading VI WPALGUI.vi
LabVIEW load error code 3:Could not load front pannel
Answered By 0 points N/A #176863
First, download Service Pack 1 (available in http://www.ni.com/labview/). When you have installed it, it should be possible to open the corrupt VIs. The initial file will probably be corrupted because the connector pane is not working but copy the block diagram and paste it into a new VI. You should now be able to use the new VI's connector pane. You do not need the corrupted file anymore, so you can delete it.
