The LaCie set-up assistant gives a “PowerPC applications aren’t supported error”
Hello buddies,
After I tried using the LaCie set-up assistant, but I keep getting this error message stating that PowerPC applications are no longer supported.
Is there any way around this?
You can’t open the application LaCie Setup Assistant because PowerPC applications are no longer supported.
OK
Best Answer by Tunacao_Caaron1
Answered By 20 points N/A #97303
Hey Akisu!
Well if I am not wrong, you must be a Mac user. I will explain you that can you avoid this problem.
First of all, to setup your disk, there is no need of application.
What you have to do is simply to format the disk as Mac. For this purpose go to utilities, select Disk Utility, from here, you have to select the disk and erase tab. Your disk will be formatted as Mac.
It is common that many of the disks come only for Windows, so to use this program you have to make it Mac format.
I Hope you understand.
Thanks
Tunacao Caaron
Answered By 10 points N/A #97304
Yes, I am using Mac. I have no idea that i just have to change the format to Mac.
Didn't realize it until now, Thanks a lot, you made my day.
It was great finding this site for technology problem.
