Lack of enough disk space
help i need to be able to delete and move emails from my inbox as am getting error message no disk space
Your question is really a critical question because i was not able to understand it. If you are running Microsoft outlook then it can cause your disk space to be used and in case you can move your emails to another drive or you can delete them or you can make archive of your emails and can compress the data in emails so you can get the space over your hard disk. If you have less hard disk space then you can either increase the hard disk capacity or you can manage your disk to maintain your emails.
Although if you are getting this error message in your email browser and you have no space in your email account then you can transfer your email account to a more available space for your emails it depends on your email service provider that how much it charges for extra space in your inbox. If you are not going to do that then you need to built a new email ID and forward all of your previous emails to such a email account then you can use both of these email accounts and you can access your data over a period of time but if you want to maintain your current email account then you need to purchase some space for your new coming Emails and that is possible if you connect your service provider.
Well, if you have a lot of emails in your inbox then it is possible that the mail is running on low disk space. Usually there is a space that is located for the mail on the server that you can use and when you reach that then you will get search an error message. That is why it is good practice to observe the following:
If the problem is with your computer running on low disk space, then you will need to create some more space on it. Use disk clean up to empty all files are occupying space and they are unnecessary.
Mathew Stone
