LAN scanning software for Mac
Hi Techyv Experts, Is there any LAN scanning software for Mac available in the internet, I am using Mac OS X 10.6 and is trying to connect the workstation to my wireless multifunction printer, which I am unable to connect.
Please do the needful for helping me.
Thanks, Ann Tanner
Answered By 5 points N/A #149662
Hello Ann
Yes there is a LAN Scanning software available for Mac.
It is called LanScan and it is a simple and effective network scanner.
I have provided you with the link from where you can download it.
Use this software if you want to connect your workstation to the wireless printer.
Just install it, and follow the instructions.
LanScan Simple network scanner
I hope you will find this information useful.
Randolph
