Language problem of Monkey browser
Hi experts, I'm using the Monkey browser.
It's the latest version of Monkey browser.
But here i got a problem.
I can't read the French fonts as well as i don't find the french fonts.
What should i do now? Any tips?
Thanks in advance.
Best Answer by Skarbos Jay
Answered By 0 points N/A #108116
Hello Arturo,
The problem is that you don't have the French language pack installed. First of all, you have to download the French language pack setup to your computer from the official seamonkey site. After you do so, just double click the "Setup" and install the language pack. After that open the browser.
Hope the advise helped.
Answered By 0 points N/A #108118
Hi, Arturo
Your Monkey browser is not displaying the French fonts because you have not installed the French fonts onto your computer. It’s very easy to install a font. First you have to download the desired font from the internet.
You will get thousands of French fonts on the internet. Once you have downloaded the font, double click it and the font will be added to your computer’s font list. You can see the installed fonts on your computer at the location Windows > fonts.
Close your browser and start again.
This will definitely fix your issue.
Thanks and regards,
Skarbos Jay.
Answered By 10 points N/A #108120
Hello Arturo,
You can download few France fonts from this URL.
Now you have a copy the fonts and just paste that font into X:windowsfont. First try that font in any word editor.
If that works in word editor than it will work on a browser. Open the monkey browser the problem is gone.
You can get so many other France fonts in internet. But the given font works fine in this browser as far I know.
Thank you,
 Riley Weaver.
