Hi there,
I have Dell Latitude E6410 and upgraded from windows 7 to windows 8 recently, then I started noticing that, while running Flash related applications, the fan was making loud noises while rotating, at first I thought there was something stuck there, after blowing the fan system, I am still getting the same noises, what could be the cause of the fan noises, and why is it making those noises when I launch particular applications?
Laptop fan working too loudly
Your laptop cooling fan is working too loudly which indicates that your laptop is hot. It's not good sign for your laptop. Do few things to solve this problems. Laptops seem to get hotter for their nature, size, increasing maximum amounts of power. You can buy a laptop cooler, which is pretty much necessary if you are playing games, editing videos or photos, or just leaving your laptops for a couple of hours with 10 tabs open then a cooler is good way to start. Beside this you can do one thing also, mainly the maximum heat is generated by the CPU, you can say CPU is main heat source in laptop. As your processor is working overtime, lots of heat generated. If you will kill unwanted programs you will do a favor for your processor. Obviously remember one thing, dust is first enemy of your laptop. So, remove dust not only for just to keep clean your laptop but also it increases airflow as a result it will boost your fan's efficiency.
