Laptop login fingerprint reader is messing up
I have fingerprint login on my windows 7 laptop. I got a little cut on my finger and now the idiot PC says that i am not authorized to login. What should i do ??
Hi there ,Â
Your problem here is that due to cut in your finger you cant get access to your computer because of authentication errors.
Ok Most probably there are secondary authentication steps which you give other than your finger print recognition authentication system. Like passwords and all . If there is somewhere the option to go for secondary authentication click on it and try accessing your Pc through that secondary method .Â
Or did you create any Flash drive that has a rescue software or a rescue disk in case fingerprint security fails . If you have done that plug in your rescue disk and then reset the passswords.
If any of the above methods didn’t worked means re -install your Windows 7 operating system and you are done .Â
