Laptop or CPU Recommendation For Multi Tasking?
Asked By 130 points N/A Posted on -
I do a crazy amount of multi taking on my main machine. I have videos and webpages open all the time. I need to invest in a laptop that can handle what my pc does. What is a great multi tasking laptop? Or what CPU should I be looking for?
Answered By 0 points N/A #185083
There are several laptops in the market but when it comes about multitasking you have to think a little bit. If you like MAC then you should go with Apple MacBook pro it has great quad-core processor, 16GB RAM, flash storage and great graphics quality.It is also lighter and great battery life.But if you do not like MAC then you should go with ASUS N550JK-DS71T.It has also great built quality.These are some great laptops for multitasking.
Answered By 0 points N/A #185082
Hi, Tyrone E Louis is you are looking for that CPU ho can give you what you need. You have to assemble them yourself. This way you can chose the best hardware to use for superpose of handling heavy work load. You have to start with the Board. Intel has the best board, and i7 will be the best processor you can have. But you must check the specs of i7 before you buy. For guide on how to choose a right processor for the right job go to this link.Intel Motherboard choice chooses the right speed that you want. Now let’s go to your RAM, 16 GB would be ideal for you working load. But you must run your OS on 64 bit if you’re running on windows 7. I recommend windows 7 coz it’s faster than windows 8 or 10. And for the finally you must have a good VGA this is not for gaming but for calculating speed especially your running a web server. GTX 970 is the fastest graphic card.
