The Laptop over fan not working and over heating
hi i have a problem with my laptop it is over heating. some time the fan was working and some time not working i don't know the problem was can you help me please.
Hello Kasmi,
It seems like the fan on your computer system has a problem and therefore it is the one resulting to your laptop overheating every time you use it.
You might want to blow the system off any dust since it may have accumulated and thus blocking the fan from fanning up the system properly to cool it hence making it to overheat. If the fan is faulty, for instance it has been broken or has some other kind of problem like being loose, then you might consider repairing it or get another new one and replace with it.
Hope this helps.
__
Regards
Mahesh Babu
It is on your computer BIOS to manage your computer fan speed. You can change the bios if you are getting some problem in heating of computer. It happens in most of computer that when are heated then the fan start working and when the fan is not working it mean that it is not over heated. However there could be some error to your fan also may be the fan is jammed due to some voltage problem or there are other number of problems in fan connection. You need to go to a computer technician and he can check it accurately. Although i can say you that when you are playing a game and your fan starts working then your fan is working properly. But if it just heating your computer then there may be some problem and you need to take action on this response. I hope you will be able to solve your problem.
