Laptop’s Battery acting Strangely please help.
I am using ASUS Laptop. Recently my Laptop's battery has started acting strangely. Even though charger is well connected to Laptop, it doesn't charge. Even if battery is low, sometimes when I start Laptop, error message regarding battery occurs, but it goes away itself? Can you suggest any solution for it?
Answered By 590495 points N/A #185685
If your laptop’s battery no longer charges even if the charger is already connected, it is possible that it has an open circuit. An open circuit causes the electric current to be cut off. So, if your battery has an open circuit inside, the electric current is cut off and prevents the battery from charging.
Like in any electronic devices, you need to have a close circuit to have a continuous flow of electricity that makes the device work. Also, if your laptop displays an error message regarding the battery, then it is obvious that you have a defective battery. Replacing the battery with a new one should fix the problem.
On the other hand, as a temporary solution if you can’t buy yet a new battery for your laptop, you can connect the charger to your laptop while using it. If the battery no longer charges, you can remove the battery from the bottom compartment and use the laptop with AC power as if you are using a regular PC.
