darenlehman
20 points
Posted on - 07/28/2011
I am looking for a laptop for school and travel, so it has to be reasonably light weight and have a good battery life. I would also like a full sized keyboard and a track pad, not the eraser type thing if possible.
Lastly, I do not want anything that is made in China like: Dell, HP, Apple, Acer, or any other cheap brand out there, but may be inclined if it has all the features I am looking for.
Thanks for any help and all info is appreciated.
Daren Lehman
Which laptop is best for school and travel purposes
Try checking the Samsung N270 Intel Atom out.
One of the lightest at 2.8 lbs, it has a 10.1 screen size and lasts up to 10.5 hours without a power adapter. It also has a full-sized 12-inch notebook style keyboard and a large touchpad. It has a robust slim line casing and is extremely portable. It costs $409.00 available in Best Buy stores.
Please check this.
Asus U53JC-XX149V Laptop:
Display: 15.6" HD LED (1366×768, Color-Shine)
CPU: Intel® Core™ i5-460M (2.53GHz)
Graphics: Switchable Graphics: NV G310M, 1G VRAM + Intel GMA 4500MHD
Storage: 640GB (5400rpm)
Memory: 4096MB (2048×2) DDR3 1066 RAM
OS: 64bit Windows 7 Home Premium
Price:807$(included vat)
nrahad51
5 points
Well,
it takes a lot to consider, when buying a laptop which meets all of your criteria. While you will get the maximum, some will miss some criteria. Considering your situation, I am suggesting a list of possible laptops which will meet your requirements.
Lenovo ThinkPad X200
Display![](https://www.techyv.com/sites/default/filesx/users/Techyv-Images/Features-of-Lenovo-ThinkPad-X200-Laptop.jpeg)
Processor
Processor class |
Intel Core 2 Duo P8600 |
Cache size |
3 MB |
HD Size 160 GB
Operating system Microsoft Windows Vista Business (32 bit)
From $1634.99
Dell Latitude E6420
- Core i3-2310M 2.1GHz Dual-core; 2GB RAM; 250GB Hard Drive; DVD-ROM
- 6-cell battery; 802.11n WiFi; HDMI; Noise Cancelling mic; 3yr warranty; Windows 7
- 14″ Anti-glare LED-backlit LCD: Intel HD 3000; Energy Star 5.0 Enabled
Apple MacBook Pro 13.3”
The base level 13.3” MacBook Pro starts at $1,199 but if you go through the Apple Education store, open to any higher level learning student, you can get 10% off the pricing. Battery backup up to 7 hrs.
Fujitsu P771
The P771 is a 12.1″ executive ultra-portable notebook with all the security, mobility and reliability features that you expect to see in a corporate notebook, but in a sleek and attractive package.
Windows 7 OS
160 GB HDD
For more information, visit here.
