eachaidh
10 points
Posted on - 11/04/2013
Hi All,
Laptop Vs Desktop iMAC which is better
I want to buy a iMACÂ and we have Desktop and Laptops
13" laptop and 15" MacÂ
21" and 27" Desktops iMAC
Mobility is not my main concern i want the best experience
Which would be best if i need it to work on a singl place
Config/Experience/cost
Since you are not running after portability, the best device you should have is the MAC desktop. Compared to laptop, it has larger hard drive so you can store larger files. It also has more ports and jacks so you can add extra peripherals. Plus, it has larger display, is much easier to upgrade and not to mention, it can be a professional ornament in your home or office.
