A Najam
15 points
Posted on - 10/03/2016
Internet is one of the basic necessities of this generation and WIFI is the icing on cake. If you cannot connect your laptop to the WIFI it could be frustrating. What to do if your laptop won’t connect to wifi?
M Sajid
10 points
Laptop Wont Connect To Wifi Interrupting The Browsing Work.
How to solve problem occurring due to weak WIFI connection?
1) TROUBLESHOOTING
If your PC has a wireless button and the wireless work is off, then click the key.
This is the key having an airplane as the symbol on it.
If this does not start the internet then go to the next step.
Open start menu.
Search troubleshooting.
Go to Network and Internet.
Click on Internet Connections.
Press on Advanced.
Click on Apply repairs automatically and then on Next.
Press on Troubleshoot my connection to the Internet and then on Next.
Follow the onscreen instructions.
If problems are present then the window will appear informing you about them.
Read the whole information to know how to resolve them.
If you can still not connect to the Internet close the troubleshot window and continue to the next step.
2) INSTALL THE NETWORK ADAPTER AGAIN
It would clean the values of registry and configurations will be reset.
3) USE WIRELESS NETWORK DRIVERS
Upgrading your adapter may solve the issue.
Go the manufacturer’s official website.
Search for the latest updates and download them.
4) RESET YOUR HARDWARE
Open start menu and click on Shut down.
Unplug your router power cord.
Wait for some time and plug it in again.
Switch on your computer.
You will be redirected to the wireless Internet connection.
Right-click on the network connection icon.
Select Network and Sharing Center.
Click on Manage network connections.
Enable the network.
Enter the password when prompted.
