alvaldez
10 points
Posted on - 04/13/2012
Hi there!
I bought a netbook last month and I noticed that the size of my netbook is just too small.
This is the reason why I'm planning to buy an external hard drive to store there some of my files.
What could be the largest storage space an external hard drive have?
I want to know this cause I'm intending to buy the largest one. Haha.
I would really appreciate your help.
Largest Storage size of an External Hard Drive
The largest one available in the market is 6 Tera Byte.
But personally I feel that 6 Tera Byte is way too much.
I mean come on why would you need a hard disk that has so much of extreme space right?
I would suggest you to go for 1 TB (tera byte) or maximum 2 TB not more than that.
But again its completely upon you which one you would like to go for 🙂
Nice question ! I heard about up to 10Tb, and it will be a massive storage.
So use a hard disk for your purpose and don’t waste,
Huge amount will be slow your system and get more memory from your RAM.
And Risk also, Try to buy few 1Tb hards and Copy your data.
That is great for risk management.
