I have a problem with my computer. I got an application error using the computer and then after a few minutes it shuts down and restarts itself. The problem repeats every time until I turn off all the programs completely. The following error message disturbed me so much.
Lasso.Client.Exe- Application Error:
The application failed to initialize properly (0xc0000135). Click on OK to terminate the application.
OK
I am in trouble so please suggest me in detail how to resolve this problem.
Thanks in advance.
Lasso Client failed to initialize properly
Hi Larry,
I also experienced that kind of issue too. What I do to resolve that is to download a Windows repair software. I would recommend you to use PC Cleaner Pro for this issue.
Once you install this software to your desktop, you should "FIX" all errors that you have seen in the scan. Another thing, you should check your registry data whether you have hidden errors. For checking registry data, you can use this utility tool.
Hope I've helped you in your dilemma.
If the problem appears after booting the computer even if you don’t start a program, the cause is probably from one of the startup applications. If this is the case, just disable that specific program in the startup. Download the free version of CCleaner and install it. Once installed, start CCleaner then go to “Tools” on the left pane and select “Startup” on the right.
Under “Windows” tab, look for the entry that directs to “Lasso.Client.exe” and disable it. After this, close CCleaner then restart the computer. If you disabled the correct program, the error should not appear. If this doesn’t work, repeat the same steps then disable all entries related to “Lasso.Client.exe” file. See if this works.
