latest adobe flash in Chrome/Chromium in Linux Mint
Hello there,
Does anyone knows how to install the latest Adobe Flash Chrome ? I have this error that doesn’t let me to make the install and I don’t know why ? Recently I made some updates in Linux and everything went just fine. Can anyone help me please ?
Thanks !
Unknown channel ‘isadora-partner’ the channel ‘isadora-partner’’ is not known.
Answered By points N/A #180459
In order to install the latest Flash Player in your Linux distribution, you must have downloaded the right installer and run its installation with root permission.
1. Go to Adobe Flash Player download page.
2. Select “Linux (64-bit)” or “Linux (32-bit)” from the list of operating system.
3. From version selection, select “Flash Player for other Linux (.rpm) 32-bit”.
4. Click “Download now” from the bottom-right corner.
5. Download the RPM package.
6. Start “Terminal’ by pressing “Ctrl + Alt + T”.
7. Run the following command to install “RPM to DEB” converter for Linux Mint.
sudo apt-get install alien dpkg-dev debhelper build-essential
8. Now, convert the downloaded RPM into DEB. Run this command:
sudo alien packagename.rpm
9. Install the generated DEB package with following command:
sudo dpkg -i packagename.deb
Now, Flash Player will be installed in your Linux Mint.
