The latest Adobe Flash Player upgrading error
Asked By 55 points N/A Posted on -
When I try to upgrade the Adobe Flash Player to latest version, I stuck up with an error message. The error message says that Flash version WIN 12, 0,0,44 found. Required version is 10, 1 or above. The version upgraded is above the required version but still I get this error message. How do I fix this problem? Please help. Thanks.
Smarlaunch Client
Flash version WIN 12,0,0,44 found. Required version is 10, 1 or above.
Answered By points N/A #167761
Adobe Flash Player is one of the greatest ways to provide users an awesome and cool graphical experience with any software, and on web. It has attracted many developers to use Flash content in their programs and so the software requires the player.
Adobe Flash Player is the way to run Flash contents on any platform. Depending on the requirement, whether “ActivX” or “Plugin” type, you have install the Flash Player on your PC so that you can execute the program perfectly.
Download Adobe Flash Player. After the installation is complete, open your software. It should run well as it should.
Before doing this update, you have to uninstall the older one. That one is too old and the latest one is v13. So, to keep your system up to date, uninstall the older one so that it doesn’t conflict with any other programs.
