Latest launching of Nokia in India
The latest released gadget of Nokia in India is Nokia 800 Pureview which is comparable to Samsung S3, would it pose an issue or threat to Samsung company since this release was said to be cheaper?
Nokia 800 series are going to be released into the market. These phones are good enough in features wise and its most important 41mp camera as other phones are not providing yet. Samsung is proving android phones at a very minimal cost. If Nokia tries to bring the android phones. Then the market of Samsung may fall. As people trust Nokia for its brand and quality. Any how when it comes to Nokia 800 series purviews the mobile doesnt have that good look. If people try to take the mobile based on look then they may go for Samsung Galaxy note. If people want to take the camera based mobiles then they may go for Nokia. It depends on individual.
If you are referring to Nokia PureView then it is not Nokia 800 that you are looking for but the Nokia 808 PureView. The Nokia 808 PureView is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on February 2012 and released on June 2012 measuring 123.9 x 60.2 x 13.9 millimeters and weighing 169 grams.
It uses micro-SIM card and has AMOLED capacitive touchscreen display with 16M colors at 360 x 640 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring Nokia ClearBlack display. It runs on Nokia Belle OS powered by 1.3 GHz ARM 11 processor and Broadcom BCM2763 GPU.
It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 1 GB ROM and 16 GB internal storage. The primary camera supports 41 megapixels where 38 megapixels is effective with f/2.4, Carl Zeiss optics, Xenon flash, and autofocus featuring 1/1.2″ sensor size, face detection, ND filter, and geo-tagging. It supports 1080p video recording at 30 fps with 4x lossless digital zoom.
It has a secondary VGA camera that supports VGA video recording at 30 fps. It has 3.5-millimeter jack featuring Dolby Digital Plus audio enhancement, Dolby Headphone, and Active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and UPnP technology support; Bluetooth 3.0 with A2DP support; GPS with A-GPS support; NFC; stereo FM radio with RDS support; FM transmitter; and microUSB 2.0 with USB Host support.
It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5 with Adobe Flash Lite support. Java is supported via MIDP 2.1. It runs on removable BV-4D Li-Ion 1400 mAh battery with standby time up to 465 hours on 2G and 540 hours on 3G. Talk time is up to 11 hours on 2G and 6 hours 50 minutes on 3G.
It is available in red, black, and white colors.
