Latest MobileNoter for iPhone update
May I know if there is an update and what are the changes it made from the previous version. Please let me know if it is also compatible with the latest iOS update.
Thank you!
Thank you!
The latest version of the application is MobileNoter 2.4 and it has a 30-day trial period for your own evaluation of the program. But you can only get the 30-day trial promo if you will register an account on their web site and then you will get the 30-day trial period.
For the PC installation, you need to download and install MobileNoter Sync Client for Windows which works on Windows XP, Windows Vista, and Windows 7. This program also requires installing these components: Microsoft OneNote 2007 or Microsoft OneNote 2010, Windows Installer 3.1, Microsoft .NET Framework 3.5 Service Pack 1, and Microsoft Office Primary Interop Assemblies. Be sure to install these components first before installing MobileNoter Sync Client for Windows to avoid any installation problems.
MobileNoter 2.4 can be installed on iPhone, iPod Touch, or iPad that runs on iOS 3.0 and later and Android 2.1 and later. You are also required to install Bonjour for Windows on your computer if you’ll be using MobileNoter on iOS. You can download Bonjour for Windows here. To download MobileNoter 2.4 and to know the complete installation instructions, please visit MobileNoter.
There a new editor has been added in the most recent iOS update. Now you may copy/paste a piece of text, resize the outlines, use a magnifying glass and undo/redo buttons.
Notifications
