Hi there! I have been notified by my Movavi Video Converter that a new version is available and so I tried to update it, but my updating was failing every time and so I decided to manually install it after uninstalling my older version. And now I my new version is also not installing. Please help me out of this problem. Thanks.
Latest release of Movavi Video Converter 9.0
Here are some solutions I am providing regarding the installation of Movavi video converter.
>> If you want install an updated version of Movavi video converter, you don’t have to remove/uninstall the previous version of it. The older version will be automatically uninstalled and the new one will be installed in your computer
>> when you try to install the converter and you notice that installer is corrupted then just download the app again and then install. Before click on download close all protection application.
>> If the installation process completes with some errors occurred and at the runtime it says can’t create object then you need to reinstall the program. And don’t forget close all other running applications before the installation and also audio, video and protection applications should be closed.
Hi!
Here I am to release you from this problem.
First of all, I need you to uninstall the previous Movavi Video Converter. This step might help you when all the errors in that converter are deleted too.
Then, you can either visit Kioskea site or Movavi site. Then, you'll see a site filled with many Movavi Video Converter varies from old version until the latest one. Choose the latest version which Movavi Video Converter version 9.1.2.
This is because the latest version has the least errors compared to others thus helping you to avoid any problem during installation. Then, simply follow the Installation Wizard.
