Latest Samsung Galaxy S III vs. iPhone
I've heard about the Samsung Galaxy S3, however, it seems that it's the newest mobile from Samsung which competes against iPhone. Now, Can somebody help me find out what are the advantages of this phone in contrast of having iPhone?
Best Answer by Crizda Bilano
Answered By 0 points N/A #161828
Hi
Students don’t pay attention in the class while in the lecture. And at the end they don’t be able to perform well in the exams and at-last fail. In class students use mobile phones and doing “GupShup” with other students. So they cannot pay attention to the lecture and lecture is more important if you someone doesn’t attend the lecture how can he perform well in the exam. Student should pay attention to this. Hope you like this answer there are many answer to this question and I like to give this answer I like this answer. Hope you also like this answer. See it looking good.
Answered By 0 points N/A #161829
I will give you the reasons to buy the two devices and I will leave it to you for you to choose the right device to your own advantage. There are reasons to buy Galaxy 3 it has Adobe flash player and is supported with phone browser, it has also free navigation software therefore you are not going to buy a navigation software, you can charge it with a USB cable that is standard, it has a removable battery so you can change it if its broken, can stream videos and TV has faster downloads has front camera quality good, it has a bigger screen size, light and thin. On the other hand the iPhone is that you can update directly, has many apps that are available, camera button allows you to get snapshots easily, has less weight, narrower, shorter, it has more internal storage, higher pixel density,  it has AMOLED, it is faster in uploading. With this given capabilities of the two it will be your choice as to what device lives out to your needs as a user.
