Latest Screenshot Captor Portable 3.05.01
The screenshot capture software Screenshot Captor Portable 3.05.01 is very functional software. Will it run in Mac OS X?
Hi Brandycarrie
Screenshot Captor is a program for taking screenshots on your computer. Screenshot CaptorPortable 3.05.01 has design for work on all windows operating system for free. You can’t run it on Mac Operating system.
Screenshot Captor provides access to a number of image editing options which can be used to enhance your screenshots once they have been captured. Sitting in the system tray, the program is always available so there's no need to remember to run it in advanced as it will start automatically with Windows.
This is the portable version, which can be run directly from USB flash drive.
Best Regards
Amanda Morson
Screenshot Captor Portable is an application designed for grabbing or capturing loads of screenshots with very minimal user intervention. It has a full image explorer with complete shell functionality and unmatched incorporation with some other external tools such as water markers and or graphic editors and supports multiple monitors. It also handles distinctive effects not available in other capture applications and this comprises the capacity to automatically find and improve the active window.
The latest version is 4.3 and is available at CNET | Screenshot Captor Portable. This new version offers a better clipboard toolbar button and already fixes the problem before when deleting old settings files into the recycle bin. It works on Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8.
