Latest technology regarding screen shot process
I would like to inform you that screen shooting is a form of picture capture of your PC screen/monitor with the use of your PC camera. This shot is considered a digital image which is taken by an operating system or software application that you are using.
The screen shot is basically used for recording or archiving as a proof of  work or display while BSR Screen Recorder is somewhat a screen shot recording but in a form of video file. It records PC screen/monitor displays with an audio. This video file can be edited and can be used for video presentations, tutorials, trainings and many more.
Below is a sample of a screen shot:
I totally got confused when you mentioned BSR in your post. I’m not sure if you are referring BSR to the application that can record screen activity or to a different program. For BSR, it can stand to several possible meanings like Business for Social Responsibility, Basic Statistical Return, Body Stress Release, Base Runs [BsR], or Bootstrap Router. These are the results I got when I tried searching the web for its meaning.
But if you are referring to the actual screen recorder software then I can recommend two of the software I am familiar with, although I haven’t actually used one of them yet.
You may try using CamStudio™ Open Source. With this software you can record all screen activities of the computer including the audio. This is very appropriate when you are preparing for a presentation. You can download it from CamStudio™ Open Source – Free Streaming Video Software. The latest version is 2.7 and it now supports Windows 7 unlike before where it only supports Windows XP and Windows Vista.
Another program that you can use is the BB FlashBack Express where you can save the movie or the video as flash or avi files. You can download this one from Blueberry software | Products | BB FlashBack Express.
