Latest technology for speeding up access to computer
How ebooster helps in speeding up the access to computer? Describe the way it is used and its memory storage capability?
Normally a computer unit stores information on its hard drive in succession until that data is found. However, this ineffective process can create unnecessary delays when loading programs. EBooster eliminates that excessive loading times by avoiding this complicated  processes.
Now, eBooster is a type of memory caching application. It simply takes the files that are accessed most frequently and stores a copy of them on a device that can read faster than the hard drive. You can either use your computer’s hard disk memory or RAM if you still have enough space for it or you can purchase a USB storage device, say 4GB USB key for example and use it as your caching device.
Whenever your computer tries to access your files, eBooster will check to see if it has a copy already to enable quick access which will speed up the process considerably well.
eBooster or ebooster, as you call it, is another type system optimization program that enhances your machine’s overall performance. Every brand of computer enhancement applications has its own way and method of making the system faster and smoother while launching different applications. The one I’m using is PC Tools Performance Toolkit and eBooster is one of its rivals. With eBooster your system will surely improve its performance because this application is chiefly designed to make your machine faster. It includes an auto-configuration wizard which will guide you in getting your machine the fastest speed plus an easy user interface for easy navigating.
Some of its features include:
It supports Windows Server 2003, Windows Server 2008, Windows XP, Windows Vista, and Windows 7 all 32-bit and 64-bit versions. To download, visit eBoostrâ„¢ | Download. The Pro version costs $29.99 but you can always download the trial version which is limited to two hours only after your computer starts.
