Latest tools for doing work faster and easier
Hi Chris, PHPEdit is one of the tools for fast, efficient, easy way of doing work. It is 50% more faster. You can download it for 30 days trial, so you can tell it yourself. You can go to, http://www.waterproof.fr/. Just for a brief description of the product. The latest version was released 5/29/2012 PHPEdit 4.3.3, to run successfully, you must follow the requirement:
1. Windows XP(SP2 or newer) windows Vista, window server ( 2003 or SP1 or newer) if windows 2000 , some features are disable
2. .NET framework 2.0 (3.5 version is highly recommended).NET framework 4 full profile (client profile is not supported)
3. 512 MB RAM ( 1 Gb or more recommended)
4. Between 60MB – 200 MB free space ( it depends on the module you want to install
If you want to know more about the product before downloading, You can go to this site: https://phpedit.en.softonic.com/
On the 30 days trial, you can get a license and if you like the product, you can upgrade, no need to install the program.
PHPEdit is a commercial IDE or Integrated Development Environment that runs under Microsoft Windows and is used to work on PHP. It offers a bunch of tools allowing you to work easier and faster on your every day work. Here are some of its features:
The above post of PHPEdit is the older one. The latest version of the application is PHPEdit 5.0 and if you want to have it, you can visit ZDNet | PHPEdit. It is priced at $113 but if you want to try it, you can freely download it from the link above. I’m not sure though if it also has the free 30-day trial period like the previous versions. This version supports Windows 2000, Windows 2003, Windows XP, and Windows Vista. Before installing PHPEdit 5.0, be sure to install Microsoft .NET Framework 2.0 because this component is required.
