Latest Trend Micro Antivirus Update For Windows System
Where can I find the latest Trend Micro antivirus update for my Windows PC? What are the essential features of this software?
The update is available at the trendmicroupdate.com website. You can choose which version of update you want to download and install it from your system location. The updates are automatically done by the software. The features of this software are,
1. Keylogger protection
2. Wireless Network validation
3. Remote file and folder permission control
4. Online data backup
5. PC tuning and cleanup features.
If you want to install Trend Micro Maximum Security, first, make sure your computer meets the requirements. Trend Micro Maximum Security supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10 both 32-bit and 64-bit. For Mac, it supports OS X 10.11 El Capitan, 10.12 Sierra, and 10.13 High Sierra. With Trend Micro Maximum Security, the default number of devices it protects is one for the default plan.
This is the cheapest subscription they offer to users for about $30 for one year. If you wish to increase the number of devices it can protect or you wish to add more devices to your subscription plan, you can select between three and six where six is the maximum number of devices a subscription plan can support.
For the subscription period, you can select between one year and two years. Supported devices include computers and mobile phones. With Trend Micro Maximum Security, you are protected against ransomware, a kind of web threat every user should avoid. Like any internet security program, Trend Micro Maximum Security also protects you from rogue and dangerous websites as you surf the internet.
It also includes parental control so you can protect your kids while they surf the internet. To purchase the latest version, go to Trend Micro Maximum Security.
