I would like to thank you for your help. I would also like to inquire whether any latest type of XII operating with Lion that can function on full screen or any other applications in a much convenient way. I would like to know how I can get access to it. I had XII in my snow leopard but using the mac application store upgrade, I advanced it to Lion, but if I can recall well, the XII had to be installed separately when I used it with snow leopard.
jhon12
Latest type of XII operating with Lion
There is now new version XII operating with Lion.
The new version of Lion OS has many new features added to make it easier to use Mac, introducing transferring files between PCs using software called AirDrop, and now you can restore the document's earlier state using the versions features.
Download and you can also buy the apps and software’s directly to your PCs from Mac App stores from their official website. Now you can keep your data much secure by using the FileVault2.
All the feature works on 32 bit protected mode. so full screen with all applications.
Lion is introducing their best feature to their Users.
Have a nice day.
