Latest version of Eraser DropPortable 2.1.1
Hi there everyone! The EraserDrop Portable's latest version is indeed very helpful but the problem it does not work when I use it in my iPad. Any solutions? Thanks!
Hi there! It doesn’t work because EraserDrop Portable works only on the following OS: 32 bit Windows 7, 64 bit Windows 7, 32 bit Windows Vista, 64 bit Windows Vista and Windows XP.So instead, why don’t you try to look for ProtectStar iShredder on the Apps Store. It does the same job as the EraserDrop. But aside from the usual data it erases, it also erases browser history, messaging logs, call history and a lot more. Just like EraserDrop, it employs erasing methods that can erase data in such a way that the deleted files cannot be recovered anymore. I used it in my iPad and it worked.
If you want to use EraserDrop Portable on your iPad, unfortunately, it is not possible. This is because your Apple iPad device is running on Apple iOS. It is the mobile operating system developed by Apple Inc. that runs Apple’s mobile devices like iPhone, iPad, and iPod touch. The EraserDrop Portable application runs only on Microsoft Windows which makes the program incompatible with your device.
EraserDrop Portable runs on Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10. If you want to use EraserDrop Portable on your Apple iPad, visit the Apple App Store using your device and find a similar application. The EraserDrop Portable application is an easy-to-use secure data removal tool. It works like any other file shredding application but in a portable version.
This means you don’t need to install it on the computer. You can copy it on a USB flash drive and open it directly on the USB flash drive on any computer and use it without installing it. To securely delete files, simply drop files to the EraserDrop Portable icon.
Notifications
