Latest version install android on samsung m1
I am using Samsung m1 that is perfect for each application. Where can I update and install android on Samsung m1? My older version was last updated on 2010.
Your Samsung m1 phone is a very good mobile phone which is similar to Samsung h1 mobile phone. But there is no specific updates or installation for your Samsung m1 phone to android. Some teams are now trying to create android Rom for this model.
But there is a android ROM for Samsung h1. Though there is a hardware difference, but you can try and download it and port it to your phone. But converting h1 to an android is a complicated task. You can check out the forum of h1, https://translate.google.co.in/translate?hl=en&sl=pt&u=https://samsungi8320.wordpress.com/category/android-rom/&prev=search and you can also download the android ROM file from this forum.
To update the operating system on your handset, you should visit your phone manufacturer’s website because normally, it is the manufacturer who provides the updates for their handset models. The Samsung Vodafone 360 M1 is not an Android-based mobile phone so updating its firmware is different from Android where you just download and install it. To update the firmware on your phone, visit Samsung I6410 Vodafone 360 M1 Firmware.
The Samsung Vodafone 360 M1 handset is a 3G device operating on 2G and 3G bands using GSM and HSPA technologies. It was announced to the public on September 2009 and released on November 2009. It is currently available. It measures 112 x 55.4 x 13.4 millimeters and weighs 111 grams. It uses a mini-SIM card. It has a TFT touchscreen with 16M colors at 240 x 400 pixels screen resolution with 3D user interface.
It runs on Linux-based LiMo R2.0.1 operating system powered by 600 MHz Cortex-A8 processor and PowerVR SGX GPU. It supports microSD expandable up to 16 GB. It has 1 GB internal storage. The primary camera supports 3.15 megapixels at 2048 x 1536 pixels. The camera can record video in 480p at 15 fps. It has a secondary camera. It doesn’t support Wi-Fi.
It has Bluetooth 2.0 with A2DP; GPS with A-GPS; and USB 2.0. The pre-installed web browser supports HTML. It supports Java. It runs on Li-Ion 1500 mAh battery with standby time up to 490 hours. Talk time is up to 10 hours on 2G and 6 hours 40 minutes on 3G.
Notifications
