Latest version of internet explorer and how to update it
What is the latest version of internet explorer and how to update it? Currently I am using internet explorer 7.
Internet Explorer 9 is the latest version of the Microsoft internet explorer web browser.
Internet explorer updates are coming with windows updates.
So if you want to update internet explorer then you have to update your windows.
To updates windows type update on search panel.
Then click on the windows update from the result.
After that you can check for recent windows updates for your computer.
Then select windows explorer and click on the install updates button.
Thank you
John major.
Microsoft Corporation develops Internet Explorer which is the most popular internet browsers. The most updated version is Internet Explorer IE 9. According to official announcement of Microsoft, IE 10 is approaching and it is expected that IE 10 will be launched very soon.
You can find and download IE from official website of Microsoft. The browser could be updated easily via Windows updates. Follow these steps.
Hope this could be helpful. Thank you.
Regards.
