Hi there! Can anyone please help me out from this problem? I have been a user of the MAGIX Movie edit for a long time. Upon the update of the recent version 16 of this software, i had to undergo a manual installation process as it was not supporting auto update for unknown reasons.
Now my new version shows that the file is corrupted. Can anyone please fix it?Â
Latest version MAGIX Movie Edit 16 problem
Like you, I am also a long-time user of MAGIX video editing applications. Currently, I am using MAGIX Video easy HD and it’s quite good and renders good video quality on the finished video.
If this is the first time it happened on your new installation, try restarting your computer then try opening it again. If it still doesn’t work and the new version is already completely installed, try doing another clean installation of the program again.
Maybe your new installation didn’t go well because of some internal errors which are already ignored by the system.
Uninstall MAGIX Movie Edit from your machine then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, or Norton SystemWorks. Install the application again after this and then check if it’s already working.
Hi!
Here I am to provide you additional solution or option for solving that problem:
This corrupted file maybe cause by any project that cannot load or even there are weird errors available.
If your file cannot load like always, you should try your luck by opening the previous version. This is theoretically based on the saved files. Usually, whenever you saved the files, the files will remain available if the Magix Movie corrupted. Thus, you can continue your work by clicking on the earlier version of Magix Movie.
Otherwise, if you encounter the problem with strange errors, you must rebed the current file into a new file. This step often solve this problem.
