bobby swank
Posted on - 10/31/2011
Hello to all! I downloaded Launcher Pro for my mobile phone wherein the extension unlocked all the widgets of my Infuse. It runs evenly and I like it so much. However, when trying to change the amount of dock pages in my home screen on the Preferences, there is no effect after doing the changes. So I reinstalled the Launcher Pro again but to no avail. What is causing this? Please let me know.
lee hung
75 points
Launcher Pro Issue on changing the amount of dock pages
Hello Bobby Swank,
The launcher pro may be good but then it may have come with its side effects one being amount of dock pages on your home screen preferences. Have you tried to change the mode of viewing the dock pages, like to the list view from the one that is currently set and see if you can see all the dock pages?
If uninstalling the launcher pro did not work, then you will need to restore the settings of the phone to the factory settings so as to eliminate any changes that have been made that are causing the problems you are having right now. Just try that and see if it will help you in way.
__
Regards
Lee Hung
