Launching ColorChecker Passport software Errors
Recently I have installed the professional photo editor software Color Checker Passport.
It was installed successfully but now when I try to load the program, it won't load and an error pops up with the following message on my screen.
The screenshot of the error is as follows:
The error reads as:
OMP: Warning #2: Cannot open message catalog “1031libiom5ui.dill”:
OMP: System error #126; Das angegebene Modul wurde nicht gefunden.
OMP: Info #3; Default messages will be used
OMP: Error #15 : Initializing libiomp5md.d11, but found libguide40.lib already in
Itialized.
OMP: Hint: This may cause performance degradation and correctness issues set en
Viroment variable KMP_DUPLICATE_LIB_OK#TRUE to ignore this problem and force the
Program to continue anyway. Please note that the use of KMP_DUPLICATE_LIB_OK I
S unsupported and using it may cause undefined behavior. For more information, please,
See http://software.intel.com/en-us/support
Has anyone else also encountered such an error?
Please do let me know what might be the reason behind this kind of an error?
Waiting for your replies.
Lopez
