Launching Final Cut 7 with FCPX Installed failed
So you are interested regarding the Final Cut Pro X and Motion 5, but you cleverly wish to stay your making talent in the old Final Cut Studio awaiting Apple can perform work on the kinks. Yes at this time and later on, you will perhaps desire to run FCPX/Motion 5 and the old Final Cut Studio in the equivalent of the similar system.
Our customer and we have not run into several somber issues running both versions, but one gotcha is. Later than you install Motion 5, you may meet an error the other time you attempt to launch FCP7:
This version of Final Cut Pro is
incompatible with Motion 5 which is
installed in a directory that previously
contained Motion 4.
Please move Motion 5 to another directory and
restart Final Cut Pro.
                    Ok
Thanking you.
