Launching Super Meat Boy Runtime Error On Steam
Hey, I’m having a problem launching the game, Super Meat Boy runtime error occurs in Steam. Can anyone guide me in the right direction to fixing this issue?
To fix this issue, you can try by verifying the game cache and changing launch options. To verify it, Click on SMB on your steam library and select properties. There you can go to Local files and select the “Verify game cache” and launch the game. If the game still crashes then try lowering the graphic details and set the game to launch in windowed mode.
If that runtime error keeps appearing on a game you just installed called “Super Meat Boy,” that problem is definitely related to compatibility. It can be a problem with the operating system or it can also be hardware. Before installing any game on your computer, make sure your computer meets the requirements. The game “Super Meat Boy” supports Windows XP, Windows Vista, and Windows 7.
Microsoft Windows 8 is not officially supported. The game requires 1.4 GHz or faster processor, 1 GB RAM, Microsoft DirectX 9.0c-compatible video card with Pixel Shader 3.0 or Vertex Shader 3.0 support, and 300 MB free space. If your video card doesn’t support one of these features then your problem is with your graphics adapter. You need to upgrade it.
The game “Super Meat Boy” is an indie game developed by Team Meat released on December 1, 2010. To download it again, visit Super Meat Boy on Steam.
Notifications
