Hello Guys!
I have a problem! I do have a lot of pc because I owned a computer shop. This error always occurred one of my PC.
I already checked other computers and also my connection.
I know I have a strong antivirus so I don’t thinks that this is a virus or any program that will destroy my pc security.
Can you help me?
Lcc runtime: GP fault, Stack trace
Fault occurred outside a function scope
Current instruction: 0x73da1d1b
reza81
LCC RUNTIME: GP FAULT Stack Trace
Most probably your winsock files have gotten corrupted.
There is a good repair program at http://www.cexx.com/, but you will have to look for it.
You can also try to reboot the system with XP CD in and follow instructions for repairing MBR files.
You must have a problem with your stack trace. It’s hard to fix that since it’s hard to find the suitable program for you. There are several programs but its ability to fix your computer isn’t 100 percent like what they say. I encountered this problem before and what I did was to restore my computer. It fixed the problem and it never appeared again.
Follow the steps I did in the screenshots below:
NOTE: CHOOSE A RESTORE POINT
Make sure the date of your restore point is before the problem occurred
