LCD | LCD TV TUNE | LCD Hardware
Hi there,
Yes you can use separate TV tuner for LCD. There are many manufactured company in the world with its separate TV tuner for LCD. They have their particular brand. I know about few separate TV tuner is used for LCD. But among them the most perfect one is “AXION AXN-8701”. You can try it.
There are many other manufactured company they have this separate TV tuner for LCD. You can found more information from their website. Also you can search for more information about separate TV tuner for LCD. This website will give you more information about it.
You just need to hook it up to a TV tuner or a Cable box. This is assuming your LCD monitor has either composite (RCA cable), component, S-Video, or HDMI inputs. You would simply buy a TV tuner, or a satellite tuner like a DirecTV tuner, and hook up its outputs to the TV's inputs. That's it. You would use your tuner to change the channels, etc. So basically, you need something like this: Samsung DBTH260F HDTV Terrestrial Tuner, Dreambox 500-c cable receiver and ITGate 220.
Remember when you decide to buy, look for something that will best fit you (Budget and Brand wise).
