Is leadtools eprint a good software for file conversion?
Hi experts! I need a good software that will allow me to convert my windows application to a PDF file.  I also need that I can set it up with multiple printers so it can be more efficient with me to do my work.  What software can you suggest? I heard about leadtools eprint.  Can you give me an assessment of its functionality?
Best Answer by Huffman Serafin
Answered By 0 points N/A #154970
Hi Olivia Talley,
Leadtools ePrint is a good software and it is good to have one. It will convert your file to PDF format the way you've typed it in word or excel, etc. Printing to multiple printers means that you can make a queue of your files to be converted and it will be converted to. If you want to add another ePrint printer, just go to start > control panel > printers > add printer > select leadtools eprint printer and then you can fasten up the conversion speed of multiple files.
Answered By 5 points N/A #154971
Hi!
 LeadTools print will allow you to create and to convert your files to PDF, TIFF, JPG, DOC, HTML it will also allow you to email, print, or combine all files. This file also allows you to convert your any Windows application in different file formats such as HTML, PDF, GIF, TXT, JPG, PING ect.
