Hey,
When I opened up my League of Legends today I got an error from my launcher. I tried to look for some solutions and ended up trying some of it without any luck of fixing the launcher. Here is the error code that I am getting from the launcher
12/30/2011 19:57 [INFO] Solid LauncherLib [1.0.0.33] initializing…
12/30/2011 19:57 [INFO] Add App[League of Legends Launcher] Exe[C:Program FilesLeague of Legendslol.launcher.exe] to Windows Firewall
12/30/2011 19:57 [INFO] Retrieving dynamic path[http://patcher.lol-europe.com/lol-cb3.SourceURL.xml]
12/30/2011 19:57 [WARNING] Error retrieving [http://patcher.lol-europe.com/lol-cb3.SourceURL.xml]
ErrorCode 950
vtech
League of legends patcher is not working
The Error message “Error Code 950” that you are getting simply means that the client program is unable to contact or connect to the server. Issues like this can be caused by a firewall, a security program or possibly with your router settings. Try to do a power cycle your equipments – modem, router, pc/laptop and try to reconnect again. This will refresh your connection and possibly your IP address if you are on automatic configuration; sometimes game server blocks (for some reason) certain IP addresses. If you still can’t connect, try to disable your firewall or security program and see if it works.
Hello Jerry Madison,
This error 905 is a security problem which is usually created by windows firewall, either you have to set it as the LOL supports or you have to disable it. For playing this game it is preferable that disable the firewall.
Go to control panel select system and security click on windows firewall now from the left of the window select advance settings, from right site of the box find out properties and select that another window will come up and in firewall stat option there is a dropdown menu from there select off, now uncheck your network connection than click ok.
Now using run open the services you writing services.msc, there is a list of the services finds out the windows firewall. Open that in that window you will find a stop button. Click on that and restart your computer. Your error 905 is solved.
You also can add two files to solve it by selecting the lolclient.exe and League of Legends.exe into the trust program list of the firewall.
Thank you,
Riley weaver.
